KING RANCH DIES on the highway
Old Sep 16, 2005 | 05:58 PM
willy2006's Avatar
Default KING RANCH DIES on the highway
The hot air duct from turbo charger to the intercooler "just blew off" according to Ford service rep.
Sounds like excessive pressure to me, any other ideas?
It is an '04 with roughly 7K miles, thanks.
Old Sep 16, 2005 | 06:10 PM
Sabretooth's Avatar
Default RE: KING RANCH DIES on the highway
Well, the entire point of the turbo is to force air into the engine by using the exhaust to power it...I'd say that if a clamp or something holding the hot air pipe was faulty or worn or damaged, it would let loose and the whole thing would come apart...i mean, the turbo spins about 10,000 rpm or so...I could see it happening without much trouble if something wasn't working to specs...
Old Nov 11, 2005 | 02:19 AM
mpadly's Avatar
This is a common problem with the 6.0l, take it to the dealer the hose is a crappy design they have a new updated part that will solve your problem...
Old Nov 19, 2005 | 01:09 PM
frdtek05's Avatar
It's actually a recall. If you have the plastic tube next to the left battery, they should install an updated aluminum tube at no charge. There's also 2 other recalls that apply to 04 f-250 and up, 6.0 diesels. One is an injector harness inspect/repair/replace and an ebp sensor and connector update. You should have recieved notices in the mail if these apply to your vehicle. These recalls are beginning to wind down as far as repairing them in the shop goes.
Old Jan 7, 2006 | 09:29 AM
Johno's Avatar
Hello All,Morning..I 'm new to this site.. having been a Ford owner the last 10 years, I finally got me a 2003 Ford 250 7.3 Lariat Pickup, its a 4x4 with about 60 k miles on it. Cuttently I will be usini it for Daily Travel to work, & occasionally will tow my Travel Trailer , weiging about 6000 lbs,
I intend to pull a 5th wheel in about 6 years time, I have a short bed.. Any information will be greatly appreciated, Im in the Dallas Fort Worth area.
phx1425
Oct 1, 2007 04:52 PM
JohnnyFord
Sep 12, 2007 11:18 AM
KingRanch72
Oct 23, 2006 04:00 PM
willy2006
Oct 22, 2005 12:32 AM
