-   Ford F-250 & Ford F-350 (https://www.fordforum.com/forum/ford-f-250-ford-f-350-15/)
-   -   Lifting a Ford F-250 Superduty (https://www.fordforum.com/forum/ford-f-250-ford-f-350-15/lifting-ford-f-250-superduty-17930/)
mjmancus Aug 14, 2009 11:37 AM
I recently purchased a 2006 F-250 with a 4" lift on the front. After inspecting it, I discovered the back is sitting just under an inch lower than the front. So I want to lift the back, so in looking at adding a leaf spring in the back they have two, one set is a 1 inch lift the other is 2 inch. But I am sure with everything they do not give a true 1 or 2 inch lift. Which should I go with?
JTGrant1 Aug 15, 2009 08:48 PM
If you want a cheap 1" lift ide just cut another leaf from an old one, and add it to the existing stack. It's the easiest, and cheapest way to level out 1-2 inches.
