mirror turn signal lens
help does anybody know how to replace the turn signal lens on 2018 ford f350 without replacing the whole mirror thanks
Welcome to the site.. Position the mirror glass ‘all the way’ rotated in and aimed up, opening up a gap at the mirror glass outer side between the glass and housing. Using a suitable length flat blade screwdriver separate the mirror upper glass from the mirror motor. If working on the drivers side,, screwdriver inserted at about the 8:00 position,, passenger side about 4:00 position. The number and location of the electrical connectors to disconnect will vary based on mirror option content. Disconnect the exterior mirror upper glass electrical connectors. |
so after i remove the mirror what holds the turn signal lens in the housing? , are there clips or screws thanks
So,, the lower spot mirror snaps in, after both mirrors are removed, you'll have access to the cover trim screws and for lamp removal.
I'll send you some info to your mail.. |
