Pass. Side Window Not working/Driver's door wiring harness broken wire
So my passenger side window will not go back up once it is put down. I have done quite a bit of tracing and found there is a short or broken wire of some kind just inside the boot in the driver's door right next to the male end of the wiring harness. Any way that I can remove the good without tearing it or cutting it? Or is there a way to go in and solder a jumper wire in on the passenger side to manually override that ? I would just buy and install a new harness but they are on back order with no date on when they will be available.
https://cimg7.ibsrv.net/gimg/www.for...daf08b74f.jpeg |
| All times are GMT -5. The time now is 04:03 AM. |
