Power is stays on
so when I turn off the ignition the engine is off but the power is still on. I have a F250 truck. What can be the issue. |
Please tell us what is happening to lead you to believe the power is still on.
Power
when i turn off the ignition the engine stops but the power stays on. And the reason I know this is because it runs the battery dead |
It is important to know what year truck you have because,
Some models have an accessory delay feature and the power windows will still work a few other things will still work for a short time even after the key is turned off. The accessory delay feature will usually turn off automatically after a few minutes. If it does not turn off , it can result in a battery drain problem and a dead battery. |
It’s a 1999 F250 |
