Rough running 5.4
hey folks ... i have a 97 f250 with a 5.4L .. would not even call it that though .. it is the 250 light duty or heavy half .. what ever you feel like calling it that day ... but i am having problems with it having a rough idle and running even rougher .. i have recently changed the following
plugs dpfe egr solenoid crankshaft sensor fuel filter o2 sensors and each thing i replace the truck continuously gets worse ... and every time i call or go to the parts house they tell me to try something else ... plus i keep getting a check engine code *p0300 random/multiple cylinder misfire* ... but sometimes i check the codes and it will tell me an actual cylinder that is misfiring .... any help here would be greatly appreciated ... |
If you have individual coil packs on each cylinder, I would try replacing the boots first, then if that doesn't fix it, buy 1 coil and swap it with each one until the problem goes away, or lessens. (You may have more than 1 coil pack defective) They will not always indicate that they are bad when you test the resistance on them, so drive it after swapping the pack.
