steering problems
Old Jun 16, 2008 | 07:37 PM
engine2's Avatar
Default steering problems
I have a 99 f-350 4x4 v-10. My problem is when traveling down the road i feel as if i am always correcting my steering. 3 different mechanics have told me 3 different things. I have been told it is the steering gear box. the brand of tires, and something in the steering column. Don't want to spend 5,000 for a $350 problem. any common problems with this year. also my ball joints have been replaced and all mechanics say they are good.
any help greatly appreciated. thanks
Old Jun 16, 2008 | 07:42 PM
david paul's Avatar
Default RE: steering problems
first i would take it to a good alignment shop and have that checked and also check and adjust steering gear free play
Old Jun 16, 2008 | 09:28 PM
Stick shift's Avatar
i doubt its a brand of tires that are making you have to correct frequently. that seems a lil far fetched.
Steering column seems more realistic, unlike a brand of tires. Poor excuse for a mechanic if you ask me.
Old Jun 16, 2008 | 10:20 PM
engine2's Avatar
alignment is good and the steering gear box has been adjusted. when my ball joints were replaced they did not replace them with greasable ones. they were replaced at 60,000 now 132000. but all mechanics, say the joints are good. what in the column would be out of whack. could it be the u-joint in the steering shaft just before the shaft goes into the box?
Old Jun 16, 2008 | 10:22 PM
engine2's Avatar
Old Jun 25, 2008 | 05:20 AM
jaxxer's Avatar
Most probably that itself could be the reason.
I also have a problem with my stearing. It doesn't turn easily, does it needs to be replaced. The car is 5 yrs old.
jaymzsun
Mar 10, 2011 08:13 PM
jaguar390
Dec 27, 2006 10:00 PM
dougsf250
Jul 18, 2006 10:54 PM
90lxstang
May 29, 2006 11:58 PM
