88 FI 460- no fuel pressure
Old 03-07-2018, 02:06 PM
draginmopars's Avatar
Default 88 FI 460- no fuel pressure
running when parked last year
Installed new battery, cranks
fresh fuel 1/4 in rear tank
full in the front.
Is there a fail switch / relay somewhere ?
Thanks
Old 03-08-2018, 08:29 AM
Always check all the fuses first.
Also should be an inertia switch in the cab ,against the firewall over the trans tunnel. you can feel the depression to confirm the button is pushed all the way down. Sometimes it can get tripped if kicked hard enough.
Old 03-08-2018, 06:29 PM
thank you for the info
was 36* here today, didn't get much done.
going to check voltage at main pump, go from there
Edwin Davis
08-15-2011 11:34 AM
Eurocoacher
05-05-2010 09:54 PM
Eurocoacher
05-05-2010 09:46 PM
59megawagon
10-15-2009 06:13 PM
Southwind13
03-26-2009 11:49 AM
Quick Reply: 88 FI 460- no fuel pressure
