Hayapower |
01-01-2016 12:48 PM |
The reusable gasket uses no sealer, if at any time another type of gasket was used distorting the pan/bolt surface, or a sealer was used and scraped off and compromised the trans smooth aluminum surface or the pan surface ground or scraped leaving the surface irregular/sand scratched/rough then the pan could bleed. Or if any pan bolts are striped, but you make no mention.. Always check the pan for flat all along the bolt surfaces with a straight edge before a reseall, more so if it leaked previously. A 'smooth' flat, clean surface on both sides of the pan seal will make for a good seal.
