2005 ford five hundred parasitic draw
Thank you.
This tells us it is a constant drain that does not get reset when the load is removed.
That makes it much easier to locate and that can be done by removing one fuse at a time and watching for when the current draw drops down.
Thanks to heiko for the wiring diagram, that makes it easy to find.
Once you know which fuse is involved, all you need to do is see what component(s) are involved and it might take a little detailed physical looking at wiring and components to arrive at a good conclusion and solve the problem.
2011_ford_escape
Sep 22, 2023 07:35 AM
usmarine0905
Oct 1, 2022 05:50 AM
usmarine0905
Sep 12, 2022 07:26 PM
