Ball Joint or Control Arm
I have a 05 Ford 500 LTD and have found the right lower ball joint has some wear and movement. Is the BJ replaceable or do you have to replace the entire control arm?
i have an 06 and pass side was worn. had to replace entire control arm. was not hard to do if you are mechanically inclined. took about an hour. good luck!
i don't see a replacement ball joint; only control arms. the price for the ca is pretty reasonable.
http://www.rockauto.com/en/catalog/f...trol+arm,10401 |
