Diagnostic Code P061B & P2106???
Took car to Auto Zone and got two codes, P061B and P2106. The man didnt know what the codes meant. Can someone please explain what this means car has been acting up lately and it's driving me insane!!:confused::mad:
Thanks in advance. |
The codes
Looks as though it maybe the throttle position sensor
me too
i have the same codes in my f-150, ganna check it out next weekend. what fixed your problem?
Codes don't tell you what is wrong
Okay... sorry for being gone so long. The problem was fixed once I convinced the dealer that pulling the heads was the wrong corrective action. They finally found a broken wire to the #4 injector, causing what the code says as a too lean of a mixture (ergo, why they thought it was a valve). Fixed wire, problem solved. Driven to Charleston and Boston with no repeat, no problems. Great little car, now!
I have an 06 Freestyle and I have both of those codes and my car accelerates by itself and then shuts off..it is crazy.
well???
My car jumped also then cut off. Autozone said codes P061B and P2106. Has anyone found out the correct way to fix this problem. I have heard that it is the throttle body......
need help please..... |
p061b
Does anyone know what this code means? My 07 Freestyle engine will rev without pushing the gas and the cut off.
Yes...your throttle body needs to be cleaned out..it is very simple and only takes a few minutes...my car has done the same thing..I have an 06 Freestyle with 95000 miles on it...You do have to continue to clean it out every so often though but it saves you ALOT of money at the dealership. GOOD LUCK!!
