Ford Five Hundred Gauge Cluster Electrical Problem
Old 06-24-2017, 10:32 AM
Glen Bailey's Avatar
Exclamation Ford Five Hundred Gauge Cluster Electrical Problem
Hello everyone i am having some crazy electrical problem on my gauge cluster on my five hundred. I have a link to a video of the problem if anyone could help it would be appreciated.
Old 07-01-2017, 04:57 PM
sketchum2's Avatar
Default Possible solution...
I too had a 2005 Ford Five Hundred that had the gauge cluster freaking out. Dials would drop to zero, lights flickered, cluster reset and had error codes popping up. Did some research and came to this link
https://www.fordtaurus.net/forums/viewtopic.php?t=15742
Had to do with cold solder joints on some of the main electrical leads on the cluster's circuit board. After getting the cluster out and resoldering the leads the problem went away. Hopefully this is the same issue you are having. It took me a day to uninstall fix and reinstall the cluster so plan on some down time. Dealer would just replace the cluster with another possibly bad cluster so I have read. Best to DIY. Good luck!
Old 10-01-2022, 06:08 AM
Shuntsman23's Avatar
Default Same problem but now car won’t start
My mom has a 2005 Ford Five Hundred 40k miles And the back up lights were on when in park or driving. And the dash lights did not come on. They replaced the battery and alternator. And a week later the car won’t start now. It has been connected to the computer 3 times and shows no codes.
jmil67
11-18-2017 03:08 PM
Glen Bailey
06-24-2017 10:35 AM
Jd1amond2
03-03-2016 12:46 PM
Kurt1s
11-04-2013 03:40 PM
fordman7
01-28-2007 12:43 AM
Quick Reply: Ford Five Hundred Gauge Cluster Electrical Problem
