grinding front end noise while braking
#21
The reason I suggested placing the trans in neutral then applying the brakes was to help isolate the noise possibly to a drive train problem that showed up when the brakes were applied. Can you do that?
Did you swap the wheels to see if the noise moved?
#22
i did not swap wheels , i will do that this evening and let you know, i checked axles again on the ground not jacked up and inner axle has some movement , but isnt that normal? i will swap tires and go coast down the long hill again see if the noise moves to passenger side !
#24
swapped tires , noise still on left side still only time I hear it is when applying brakes.. now going to.look at axle replacement and seals
LittleBoo55
11-10-2017 02:13 PM
