grinding front end noise while braking
Old 05-13-2018, 03:42 PM
The reason I suggested placing the trans in neutral then applying the brakes was to help isolate the noise possibly to a drive train problem that showed up when the brakes were applied. Can you do that?
Did you swap the wheels to see if the noise moved?
  #22
Old 05-13-2018, 05:52 PM
drive805's Avatar
i did not swap wheels , i will do that this evening and let you know, i checked axles again on the ground not jacked up and inner axle has some movement , but isnt that normal? i will swap tires and go coast down the long hill again see if the noise moves to passenger side !
  #23
Old 05-14-2018, 02:45 PM
There should be no movement of the parts except turning.
Coast will not be the same as applying the brakes immediately after taking it out of gear.
  #24
Old 05-14-2018, 04:20 PM
drive805's Avatar
swapped tires , noise still on left side still only time I hear it is when applying brakes.. now going to.look at axle replacement and seals
Eric Larsen
04-29-2018 09:07 PM
LittleBoo55
11-10-2017 02:13 PM
SundownSVT
04-22-2008 12:08 AM
rhino68
11-13-2006 11:58 PM
Quick Reply: grinding front end noise while braking
