-   Ford Five Hundred (https://www.fordforum.com/forum/ford-five-hundred-67/)
-   -   keyless code???? (https://www.fordforum.com/forum/ford-five-hundred-67/keyless-code-5013/)
derekjett Aug 28, 2006 09:51 PM
keyless code????
Where do i find the factory keyless entry code on my new (used) 500???
94 4x4 ranger Aug 28, 2006 11:50 PM
RE: keyless code????
[sm=welcomesign.gif] Not shure but try the glove compartment box for a sticker.
Mulletman Aug 29, 2006 02:36 PM
You might have to take it to a Ford dealer so they can retrieve the code with the computer. It may cost around $60.00 to do it though.
cobra79 Mar 3, 2007 09:27 AM
I think it is located on the module .
95electricblue Jul 5, 2007 11:15 AM
I'm going to look for my code tonight. Did you find your code and if so were? I have a 2006 500
95electricblue Jul 6, 2007 02:05 PM
No luck finding the code. Under dash both drivers and passengers between the front and back doors. No luck please help Ford has gotten more then enough of my money and they do not need the extra $60
Troy
john412 Jul 19, 2007 12:33 AM
Not sure if it is in the same spot, but on the freestyle(same platform) it is behind the fuse box. You have to look under the steering column and remove the three nuts that hold the fuse box. Don't unplug cables, just move the box so you can see behind it with a mirror. You should see the 5 digit code. Hope this helps.
techmanbd Jul 19, 2007 10:11 AM
I have also read before, in cars the number is in where the spare tire is. Not sure, but wouldn't take much to check out.
RHNiles Oct 17, 2007 06:28 PM
Never mind all the drivel I just posted, I didn't notice the year posting wasn't this year! Sorry
If you know the dealer from where it was purchased new, they will have it in their files on the car. There is a factory combination that works and overides the customer set code. If the person who had it before you set a code you will need that factory code to clear out the previous one and set it to your own code. The car will revert to the factory code anytime the battery power is turned off for any reason, so the dealer should give you the code with no problem. Also the factory code will still work even if you have set your own code, so it would be a good idea to try to remember it also.
Rick
sonny32 Jan 24, 2009 11:23 PM
This is for all those who want to know,,(as I did) The code for the KEYLESS door opener,is located on the INSIDE of the cover over the CONTROL MODUAL,,(COMPUTER),, which is located under the dash in front of your left knee,(as you sit in the drivers seat)...
Good luck taking off the cover it is a real pain,,, but you my be able to just take out the 2 front screws ,pry it down and use a mirror... Good luck to all..
sonny32
