No Heat
Hi First time here i have a 2006 ford 500 SEL AWD 3.0l i have no heat antifreez was low took a gallon to fill the tank and i ran to car for about an hour to warm it up and still no heat and the hoses are cold the fan kicks on and the temp gauge took forever to get to normal range any help would be great thanks in advance
UPdate got heat now found out it was air in the hoses bled it out and all set
Thanks for the update.
Do you think it would be a good idea to find where the missing coolant went? You might consider this a sort of warning that something is leaking. Unless you already checked it and found the answer. |
