-   Ford Flex (https://www.fordforum.com/forum/ford-flex-74/)
-   -   po301 code (https://www.fordforum.com/forum/ford-flex-74/po301-code-45370/)
baker018 Apr 4, 2022 07:30 PM
po301 code
Have a 2011 e-series van that on occasion check engine flashes for 30 to 40 seconds then goes out.Ran a scan and found a po301 code. Mechanic changed out all spark plugs, wire harness and coil pack for cylinder 1 plus did a fuel induction service. This did not correct the problem. The engine runs fine otherwise.
raski Apr 5, 2022 04:00 AM
You paid him to solve your problem, he did not fix it. I would take the car back to him.I hope he also changed the coil's boot and used OEM parts since aftermarket coils can be questionable in quality. Coils can be easily swapped for testing. Things to check/try is to swap the #1 fuel injector with another cylinder. Check injector #1 wiring and the coil wiring for #1. A intake manifold leak could be causing a lean miss for #1. Lastly, perform a compression test of all cylinders.
