07 focus both rear windows stopped working
Both rear windows stopped working. I've checked fuses #54 & #55 (there both ok). I probed the driver's door switch with a test light. I've got power going to the switch. I have a signal for the up and down on both front windows, no signal for either rear window. I took the switch out, thinking it's a bad contact or the window lock button was stuck in the on position. I've tried forcing the connection on & off. It didn't make any difference either way I tried. Any suggestions would be great. I'm getting ready to purchase a new switch for $100. I just want to make sure there's nothing else it could be before I do.
5 Attachment(s)
Ok here is the wiring diagrams and related connector views. Remove the rear door panels and check for voltage first at the motors if not there then check at the window switches.
