2005 Focus - Headlight Replacement Issue
Old Jan 16, 2008 | 01:26 PM
skeefe978's Avatar
Default 2005 Focus - Headlight Replacement Issue
I'm not completely inept with cars, but I can't seem to get my headlights out. I took the rubber boot off, unplugged the wire, but that's as far as I got. The owner's manual says to turn the bulb counterclock wise, but it won't budge. Any thoughts???
SK
Old Jan 16, 2008 | 03:26 PM
btexpress's Avatar
Default RE: 2005 Focus - Headlight Replacement Issue
Sounds like you performed what the manual says to do, remove the headlamp bulb cover, disconnect wire connector and remove bulb. Maybe give it a little twist while pulling?
Old Jan 16, 2008 | 08:53 PM
skeefe978's Avatar
I'm at a complete loss. I cannot get the bulb to twist in either direction - and it won't pull straight out. I hate the thought of paying a dealership to change a bulb! Help!
Old Jan 16, 2008 | 10:35 PM
The bulb (HB5/9007) doesn't twist itself.. The 'retaining' ring does.. Once the protective cover is removed, twist the retaining ring to unlock the bulb.. The bulb has an oring on it's base for sealing.. It can 'stick' a tad, but generally it will just pull witha light pull...
Old Jan 17, 2008 | 11:34 AM
skeefe978's Avatar
This is great. Thanks for theinfo, becausethe freakin owner's manual doesn't say anything about the retaining ring!
HaraldvE
Dec 12, 2010 02:53 PM
2346home
Jun 22, 2010 12:47 PM
markr
Nov 21, 2006 10:16 AM
daddio360
Jun 13, 2006 07:37 PM
jjoneskaty44
Feb 27, 2006 01:10 AM
