2013 Focus DTC Code P07A3
Old Jul 12, 2020 | 03:04 PM
MikeySmiles's Avatar
Default 2013 Focus DTC Code P07A3
Hello, new to this forum but I belong to several others as I like to help my friends out when I can. A 2013 Focus shows a DTC code P07A3, "Transmission Friction Element A Stuck On". The car begins to bog down and has no power when the trans shifts to 2nd gear. My research showed that there may be a problem with the ground wire of the negative terminal of the battery. I sanded the mounting tab on the left front shock tower, sanded the cable tab and cleaned the bolt. Then went back and cleared the code. The car now runs good but I don't know yet if the problem was solved. Does anyone know if this has any other fixes I should know about and is it something that I can fix without going to the dealer? Any advise is greatly appreciated. Thanks.
Old Jul 12, 2020 | 03:17 PM
scott.butler4's Avatar
Do you have access to IDS or other software that allows you to view live data PIDs?
Old Jul 13, 2020 | 07:42 AM
No sir.
Old Jul 13, 2020 | 12:52 PM
If the code comes back I would recommend taking to a shop (dealer or indie) who has a scan tool that can view live data(dealer of course has IDS).
Only diag ford has is quick but you have to view the live data pids.
Austin Cymbalski
Mar 21, 2021 07:50 PM
Fourder
Oct 17, 2013 08:15 PM
focus123
Feb 6, 2013 02:41 PM
cosmokramer
Nov 29, 2009 09:28 PM
