Electric windows not working
Ho All,
electric windows not working on either side see video https://youtube.com/shorts/Ei2uVmo-l9U?feature=share have tried replacing fuse 127 its a Ford Focus Zetec 2008 so MK 2 anyone got any ideas how to diagnose and fix? thanks for any ideas :) |
What I try to do is ,
Remove the window switch assy and with a test light or voltmeter verify power is getting to the sw assy and going out when a function is selected. Depending on the result obtained will determine where we go from there. Many times there is a broken wire in the driver's door hinge area , and gently pulling on each one can help when you find one that is a little stretchy. |
Thanks!
I gave up and got an electrician out. He took the door off. Unhooked the door electric plug from the body and found an earth wire had come unstuck from the plug. He secured the wire into the plug and everything is working again :) |
Thank You for the update.
