Electrical Problem
Old Mar 20, 2020 | 07:35 PM
katzman2's Avatar
Unhappy Electrical Problem
Disconnected and removed a battery from a 2005 focus to charge it (weather too rotten to try charging in the car). When I reinstalled the battery, the factory tamper alarm goes off (horn sounds and head lights show), but will not turn off using the unlocker (4 button-lock, unlock, red button, blue button). Car key not helpful. Any ideas what causes this?? What will fix? The car is a 2005 Focus ZX4 SE 2.0 engine. The battery was low enough it took all night to charge.
Old Mar 23, 2020 | 12:02 PM
katzman2's Avatar
Default Electrrical Problem
The battery checked with a dead short internally. Car starts after replace, but charging system not woking.
Old Mar 23, 2020 | 12:33 PM
If it were to be jumped reverse polarity, or a dead short of any kind, Id check the fuse in the BJB #10
Old Mar 23, 2020 | 01:13 PM
katzman2's Avatar
that fuse is good. passes continuity test also-ckd multimeeter
Old Mar 23, 2020 | 01:43 PM
katzman2's Avatar
Reinstalled the fuse and problem went away (battery icon on dash went out).
Old Mar 24, 2020 | 11:11 AM
Thanks for the update...
jamichau
Aug 9, 2017 07:57 PM
amc8381
Jun 11, 2012 06:54 PM
hfb1957
Aug 20, 2010 01:43 PM
focusrocker
Jun 26, 2008 01:14 AM
snicholsgirl
Apr 24, 2007 01:32 PM
