Focus for my daughter
Old Aug 3, 2013 | 07:49 AM
Rustyfly's Avatar
Default Focus for my daughter
Looking for a focus for my daughter. Unfamiliar with model. In general, would you buy an older one with low mileage or would you buy a newer one with higher mileage?
Any red flag issues to be wary of?
Any thoughts would be appreciated.
Thanks,
Steve
Old Aug 22, 2013 | 07:52 AM
pyroinsa's Avatar
Old Focus Engines (200-2004):
Red flag is this engine:
* Valve cover usually unpolished aluminum, silver in color, with "2.0L Split Port" cast into it * Valve cover has 3 bolts in the top middle, holding it down * Spark plug boots are on the front of the engine, above the exhaust manifold * Oil cap is in the top center of the valve cover * Front of valve cover has 4 "humps" that stick out, with indentations where the spark plugs go * Found in all Focus LX's from 2000-2004 * Found in certain Focus SE's from 2000-2004 * Found in all 5-speed Focus Wagons for the 2000 model year
Pictured ABOVE: The 2.0 Split Port engine, commonly called SPI, will have catastrophic engine failure at any time!!!! Google Ford Focus SPI dropped valve seat to find out more
* Valve cover is usually black, and bearing "Ford" and "16v Zetec" logos on it * Valve cover has 4 spark plug boots running down the middle, with two raised areas in front of and behind the spark plug boots * Oil cap is in the front drivers side corner of the valve cover * Found in many 2000-2004 Focus trim levels * Not available in the Focus LX. * Not available in 2005 and newer Focus
Pictured above: The 2.0 Zetec. It's a very reliable engine and it's a non-interference engine which makes it very easy to work on. Common problems are the thermostat housing, and the wiring for the alternator on earlier years is faulty.
2.0 Zetec SVT
* Valve cover is aluminum, with a silver color to it. * Spark plug wires and coil-pack are covered with a black plastic shroud, with an SVT badge over the spark plug wires * Oil cap is in the front drivers side corner of the valve cover * Found only in 2002-2004 Focus SVTsPictured above: The SVT engine has the same common issues as the normal Zetec, this one IS an interference engine.
Duratec Engine (2004-2011)
* Intake runner is on the front of the engine, and is black in color * Contains a very elaborate air intake and air filter system * Coil packs are mounted on top of the (barely visible) valve cover * Engine bay, in stock form, looks somewhat cluttered with cables and hoses for emissions purposes.
Pictured above: The duratec engine has a lot of Torque, therefore, the automatic tranny's were known to fail. This one has a timing chain. There is what's known as a 2.3 PZEV version of this engine found in some of the 2004 models. This engine was a requirement in the "green" states. Ford also used this engine in the 2006 version of the Focus ST.
Duratec TiVCT (2012-present)
Found in the newest model of Focus, this engine is based on the previous Duratec.
My recommendation would be either the regular 2.0 Zetec or a Duratec engine. You can't go wrong with either of these 2 engines and I know guys right know with more than 300,000 miles on these engines.
Old Aug 29, 2013 | 10:08 PM
makuloco2000's Avatar
Duratec is the one to get!
lossTig
May 29, 2015 02:06 PM
Doug Funny
Nov 1, 2009 12:32 PM
