-   Ford Focus (https://www.fordforum.com/forum/ford-focus-25/)
-   -   Proper ATF (https://www.fordforum.com/forum/ford-focus-25/proper-atf-38376/)
David A. Pikul Aug 3, 2018 06:58 PM
Proper ATF
Can I use castrol Dex/Merc on my 2004 Ford Focus manual transmission instead of the Motorcraft which is $24/per bottle?
hanky Aug 4, 2018 08:11 AM
Check your owners manual I believe it specifies this spec for 5 speed manual trans, WSD-M2C200-C .
If the container says the lube meets that spec, it should be OK.
