Turn signal dont work
Hello im am having a problem with my turn, hazard signals does anybody know where i can locate the relay or fuse my manual is very vaige thanks
RE: Turn signal dont work
This is for your Focus,, Correct? I moved the thread, if it's for a different application let me know... What year is your Focus, and whats the issue with the lights?
Sorry Sir I am a newbie, well its a 2002 ford focus ZX3 I think I blew a fuse or relay my turn and hazard doesnt work I hear it cliking inside but the acctual light doesnt come on also my brake lights are not getting brighter when i step on the brakes just the third brake light turns on. My manual is vaige I am not sure wut fuse or relay to check or how to check to see if a relay is bad thanks
Not a problem,
Since the High Mount brake light still works, that should eliminate the fuse and the stoplight switch .. Could be a problem in the multifunction switch, or the turn/stops functions are run through the GEM module.. Fuses for turns/stops are #32/15amp and 42/15amp.. |
| All times are GMT -5. The time now is 04:40 AM. |
