Cam Shaft Seals Help Please!
A couple of weeks ago I replaced the cam belt on my MK1 16V Focus 02 plate and I decided to replace the cam shaft seals on the cambelt end.
The original seals were level with the side of the head however the new ones I tapped in as far as they would go and I'm not sure if I should have done that, will it be okay? |
Depends on how much sealing surface is contacting the seal..
