HELP..... reset procedure 2004 Ford explorer XLT V6
I've tried everything I put a new throttle position sensor on tried to reset procedure did not work I've tried other things that I've seen online nothing is working can somebody please help ASAP
A forced reset will not work all the time.
Need to know why sensor was replaced, what was the original problem and what codes if any. If the sensor was replaced and the problem is still present, it could mean the sensor itself was not the problem. Many times wiring connections are the culprit and there may be more than one sensor. involved. |
