Non drive, non abs rear wheel hub and bearing assembly
, i am looking for a wheel bearing and hub assembly for a non automotive applicatioin.
A timken 512000 could work but timken says the unit is for a 2000 year range car and may not be around. I want a 3 or 4 wheel bolt assembly with bolt circle from 3.5 to 4.5 inches, tapped holes on wheel mount flange. I can create a mount on the frame side to duplicate the vehicle mount. I am assuming car or light truck. Is there a ford product, 2010 or newer that would use a non drive, non abs assembly? Timken and moog and gsp make aftermarket units. Steven peek, pe |
