RV hitch issue
Old 09-19-2018, 08:15 PM
maison's Avatar
Default RV hitch issue
2018 F250 4x4 Diesel. Pulling an 8000 lb RV. When I insert the hitch bar into the receiver, including the 2 1/4 “ spacer, the hitch bar has quite a bit of movement in it regardless of which hole I put the pin through. Is this normal?
Old 09-19-2018, 10:42 PM
Thumbs up
Welcome to the site..
Receiver/draw bar play is common. More so on the new hitch combo with the 2 1/4 bushing. If you can eliminate the bushing with a new hitch/bar then you reduce some of the slop. They make hitch rattle eliminators/silencers but not sure about working on the 2 1/4 ..
Kathy Patterson ORourke
10-12-2017 07:54 AM
Ghostrider33
05-10-2016 12:02 PM
HitchAnything
03-07-2014 01:36 PM
CoyoteRoede
08-25-2006 07:30 PM
fordDriver8888
08-11-2006 09:20 PM
Quick Reply: RV hitch issue
