-   Ford Freestar (https://www.fordforum.com/forum/ford-freestar-17/)
-   -   04 Freestar 3.9 P0171 Lean Code (https://www.fordforum.com/forum/ford-freestar-17/04-freestar-3-9-p0171-lean-code-35548/)
BradT Feb 10, 2017 06:54 AM
My 04 Freestar w/ 3.9 has been throwing a P0171 Lean Code. Recently had an EGR code too. When replacing EGR noticed IMRC rods were off. Replaced bushings with aftermarket ones, rods continue to pop off.Could this be causing lean code or do I have an additional problem? Was going to replace all IMRC with Ford bushings this time. Do I possibly have a bad O2 sensor also?
hanky Feb 10, 2017 11:49 AM
Best to take things one at a time. Fix the bushing problem and see what happens after clearing the codes.
BradT Feb 19, 2017 05:05 PM
Replaced IMRC bushings and still getting the P0171 code. Am I safe to assume I possibly have a vacuum leak somewhere causing this lean code?
Littlehawk Nov 18, 2017 03:02 PM
Hey, Did you ever get it solved? I have a code U1059 that the ABS circuit is not communicating with the instrument cluster. Any ideas what specific problem that could be?
