'05 4.2L Clicking When Accelerating Only
Just like this video
https://youtu.be/rrewaozoiWg anyone else have this issue and figure out what it was? I've had a couple people say either a flex plate or Torque converter. The sound only appears when you step on the gas but if you baby it a lot it won't happen too much. After a while the flashing gear symbol with the exclamation point will appear on the dash (Powertrain malfunction). |
Justin,
Has the torque converter been replaced under the recall? I would get the code identified to see what the PCM says it detects. The clicking could be a torque converter blade broken loose and hitting the stator, this was the reason for the recall. |
Originally Posted by prkvllhlldwlr
(Post 109018)
Justin,
