2004 driving lights/lamp question
Hello.
I just purchased a 2004 ford freestar, and I have a few questions: #1.) Mine was made in Canada or by ford canada. The VIN starts with a 2. Does this have the driving lights? You know the ones that are always on? #2.) I was looking at the headlight, and noticed a small white bulb in between the headlight and blinker, but it doesn't seem to come on for anything. That's about it for now. Thanks in advance for your time & help. Kevin |
RE: 2004 driving lights/lamp question
Do you mean DRL? Day time running lights...
Is it #6 in the picture? [IMG]local://upfiles/6756/F04D839369284AC5B4A4C8F068DF9C27.gif[/IMG] |
Yes I believe so. I attached a image clearing showing the bulb/light section I'm talking about. Please check this, and let me know. Thanks. I do mean the DRL. How do I turn them on?
http://www.scanthis.com/PIX/light.jpg |
That small bulb I mentioned was a marker light..
Here's the DRL info.. IF the SJB (smart junction box) is configured for daytime running lamps (DRL), this feature illuminates the low beam headlamps at a reduced intensity when the following conditions exist: [*]the ignition switch is in the RUN position[*]the headlamp switch is in the OFF position[*]the autolamps feature has not illuminated the exterior lamps[*]the transmission is in DRIVE[/ul] |
My van doesn't have the AUTOLAMP option. So I dont have DRL, right?
The light I pointed out in my image above doesn't light up at all. Any ideas? |
Could it be the sensor to tell the computer when the running lights should turn on?
By the way - he already said there is no other bulb for the system - it just lights your regular low beam headlight automatically and not as bright.
I'm not sure what this bulb does. This is what I'm asking here.
Also I want to know if my van has DRL or not. I was told if it was made in Canada it's standard to have DRL. |
Soooooooooooooooooo
If I dont have the AUTOLAMPS option on my headlamp switch I don't have DRL? |
Not necessarily..
Autolamps and DRL are two functions which can be configured in the SJB. (smart junction box) The function/requirements for DRL activation would be the same only with no autolamp.. The DRL's are actually the lowbeam headlights with a lower illumination by a pulse voltage.. The small bulb 'looks' like a side marker light.. |
