Check engine light - 4 codes
Old Nov 4, 2012 | 03:40 PM
ugh3012's Avatar
Default Check engine light - 4 codes
The check engine light came on. I took it to Advance Auto store and borrowed the code reader. The following codes are:
- B1317 battery high volt
- C1288 unknown code ( I did some research on the internet, and this is what I found. C1288 - Faulty Pressure Sensor for brake)
- P0171 oxygen sensor bank 1
- P0172 oxygen sensor bank 2
It just seems werid that all four codes popped up at the same time. So, I thought maybe something else is wrong and the PCM misinterpret the real problem.
Any thoughts?
Thanks
2004 freestar 4.2
CharlesC
Nov 19, 2010 07:11 PM
oneway
13
Nov 8, 2010 10:34 PM
98contour
Oct 28, 2008 04:29 PM
tgreyesp
Jun 29, 2008 04:23 PM
