-   Ford Freestar (https://www.fordforum.com/forum/ford-freestar-17/)
-   -   Check engine light - 4 codes (https://www.fordforum.com/forum/ford-freestar-17/check-engine-light-4-codes-28459/)
ugh3012 Nov 4, 2012 03:40 PM
The check engine light came on. I took it to Advance Auto store and borrowed the code reader. The following codes are:
- B1317 battery high volt
- C1288 unknown code ( I did some research on the internet, and this is what I found. C1288 - Faulty Pressure Sensor for brake)
- P0171 oxygen sensor bank 1
- P0172 oxygen sensor bank 2
It just seems werid that all four codes popped up at the same time. So, I thought maybe something else is wrong and the PCM misinterpret the real problem.
Any thoughts?
Thanks
2004 freestar 4.2
