Door lock stuttering
Recently my driver door lock has started stuttering, it was only doing it when unlocking but tonight it started doing it when I lock it as well. Sometimes I must hit the unlock button three times to get the drivers door unlocked. Will this door lock eventually stop working alltogether? Can anyone tell me what the problem is? Is this something that only a mechanic can fix and do you know if it is an expensive repair? Thanks!
Originally Posted by colorado2mama
(Post 66322)
If the remote entry works fine but the switch is causing the stutter, then I would blame the switch - it's not uncommon to have water entered into the switch and damaging the contacts. HTH .. let us know how it goes. Good luck! |
| All times are GMT -5. The time now is 09:38 AM. |
