Freestar (2006) Not Providing Interior Heat
My Freestar is not providing interior heat. Instead of the heat control **** rotating from cold on left to hot on right, the **** can spin continuously. I pulled off the **** to verify that the shaft is rotating with the ****, and it is. There is little resistance to rotation - spins easily. Could it be detached from the blend control? Is it electric or mechanical? Anyone have this issue? I need some heat; thanks.
You might want to look at the back of the control ****. . There is usually a flat side on the shaft of the control that indexes with the flat side of the ****. If the **** is cracked it will rotate easily and not move the shaft of the control.
hanky:
Thanks for that; I did confirm that the flat of the **** (not cracked) is on the flat of the shaft. When I pull off the ****, the shaft is very easy to rotate without the ****. It seems odd that the shaft rotates continuously; I think typically there are stops at full Cold and full Hot.
How much needs to be replaced? On Rockauto, I see this part. Is it what I am looking for?
FORD > 2006 > FREESTAR > 3.9L V6 > Heat & Air Conditioning > Heater Air Door Actuator
The control is a separate part from an air door actuator.
Suggest you call them and verify that you both are talking about the same part..
That is the benefit of going to the place and see just what they try to sell you If you buy on line and get the wrong part, happens often, been there now you have more problems than when you started. If you have no experience taking a sash apart,might consider having a good shop do the job.
I am no stranger to tearing into dashboards, I was just hoping to determine if that is needed. The blend door actuators are above the accelerator pedal, but the heat control is in the dash. This problem has become intermittent, so I may be searching for a loose connection.
cleocutie
10-16-2017 03:34 AM
