Freestar Liftgate Handle Illustrations
Liftgate Illustration #1 License plate Housing
http://www.keepandshare.com/doc/5695...-pdf-154k?da=y Liftgate illustration #2 Liftgate Trim Panel http://www.keepandshare.com/doc/5695...-pdf-212k?da=y Liftgate illustration #3 Liftgate Latch http://www.keepandshare.com/doc/5695...-pdf-236k?da=y |
Hi there, I have an 04 freestar and my handle came off too, I subscribed to keep and share to see the pdf files but I may I have your permission to view the files? Thanks for any help
Welcome to the site..
Free to view, hope they help.. |
Thank you, but when I try clicking on your 3 files, I cannot view them because keepandshare says you have to set the "sharing controls" in your keepandshare account to allow me or anyone else access to view them. I have a keepandshare account as well so I can give you the info you need to allow me permission to view it, or you could email me, probably easiest?
Thought I had already set for share..Should work now..
These illustrations are to gain access to the handle, not an upgrade or fix. You might try searching the posts, some have had some luck re attaching. If you need help, let us know.. |
Thanks, hopefully we can reattach the handle as its not broken, I assume it just slid off. I appreciate your help
my mechanic says he has the part i just haveto make some money 4 it thanks
Rear gate lock is stuck in lock position
How do I open the locking clasp on the rear gate? The handle is unable to open the clasp that closes onto the rear hook located at bottom of trunk.
Where is the buzzer for the lift gate? Sounds like a back up warning. sometimes it takes several tries to get it to shut up. .Wanna remove it.
