freestar rear window defoger
Good day everyone !!!! Just a plain question: How I can reattach the contact for the rear window defogger,(looks it was originally solder to the glass), is three any kit or glue to do this?
Thanks Dimasp28 |
When the rear defroster does not work at all, small breaks in the horizontal grid can be eliminated as the problem. In this case, all of the horizontal defroster grid lines would need to be broken and it is very unlikely that this would happen without it being immediately obvious. Begin trouble shooting a total grid failure by carefully inspecting the thick vertical side bars of the defroster. A break or scratch in one of these bars could cause the defroster to fail completely.
Use the Frost Fighter Defroster Grid Kit to repair any small breaks or scratches in these critical side bars. The more likely cause of a total defroster grid failure is a separated main power clip/tab. These critical tabs connect the defroster grid with the vehicle’s high amperage defroster circuit and are located on each of the defroster grid’s vertical side bars. These all important tabs can be knocked off of the defroster causing total defroster failure. Look for dangling wires near the sides of the defroster as a sure indication of this problem. |
