| MikeyS |
Aug 20, 2009 07:46 PM |
Front Washer pump failed
There is one washer pump on my 06 freestar. It has 2 outlets, one feeds the front and one feeds the rear. It is controlled by pressing the front washer button in on the signal arm, and there is another rotating switch which sprays the rear window. The rear window washer sprays ok, however the front washer does not spray at all and the motor does not operate. Is there a relay for the washer pump to control the front spray. I think the pump turns ccw for the front and cw for the rear spray.
