-   Ford Freestar (https://www.fordforum.com/forum/ford-freestar-17/)
-   -   Half shaft replacement walk through (A step by step guide) (https://www.fordforum.com/forum/ford-freestar-17/half-shaft-replacement-walk-through-step-step-guide-36777/)
RiflemanD Sep 18, 2017 05:39 AM
Disclaimer: I am not a mechanic, so do this job at your own risk. If you do not feel comfortable with this, and feel it's outside of your abilities, take your vehicle to a mechanic.
Tools needed:
  1. Jack
  2. Jack stand
  3. Kroil (or similar penetrating oil)
  4. Anti Sieze
  5. Breaker Bar
  6. 1/2" and or 3/8" drive ratchet
  7. 19MM Socket (or 3/4" socket)
  8. T50 Torx
  9. 30MM
  10. 12MM Socket
  11. 18MM Socket
  12. 13/16" Socket
  13. Pickle Fork (Ball Joint Removal Tool)
  14. Impact wrench (if necessary)
  15. Torch
  16. Cut Off Tool
  17. 4lb Hammer (or similar)
  18. Zip Tie
  19. Grease Gun
Step 1:
Be sure to be on solid level ground.
Step 2:
Use your breaker bar (or four way) with a 3/4 socket to loosen your lug nuts (do not remove them fully, just yet).
Step 3:
Place jack under vehicle and raise it up to a comfortable level. Place jack stand underneath.
Step 4:
Continue to loosen and remove lug nuts, and wheel.
Step 5:
Soak all your bolts and nuts with penetrating oil.
Step 6:
Take your ratchet and 12MM socket to remove the caliper bolts from the caliper to the bracket. Once removed zip tie the caliper out of the way.
https://cimg0.ibsrv.net/gimg/www.for...0cf978fefd.jpg
Step 7:
Take your 18MM socket and remove the caliper bracket, set aside for later.
https://cimg9.ibsrv.net/gimg/www.for...44a394c1bf.jpg
Step 8:
Take your T50 and remove the torx bolts holding the rotor to the hub assembly. Set rotor aside.
https://cimg8.ibsrv.net/gimg/www.for...3c5989d586.jpg
Step 9:
Use 3/4 socket and pop off the outer tie rod from the knuckle assembly. *bonus* Jam nut is also 3/4, if your tie rod is bad, go ahead and replace now.
https://cimg2.ibsrv.net/gimg/www.for...14aebe2759.jpg
Step 10:
Use a 3/4 socket to remove sway bar link or a cut off tool, replace if necessary.
https://cimg6.ibsrv.net/gimg/www.for...eaf820785a.jpg
Step 11:
Use 3/4 socket to loosen and remove lower ball joint nut (bolt head is 7/8 I believe, I forgot to take a photo of that, sorry).
https://cimg3.ibsrv.net/gimg/www.for...7f2cb6e701.jpg
Step 12:
USE CAUTION HERE Carefully insert your pickle fork between the LCA and the knuckle assembly as to not tear your BJ boot. Pry up until BJ is free from knuckle.
Step 13:
Use 13/16 socket to remove the bolt holding the strut to the knuckle assembly.
https://cimg4.ibsrv.net/gimg/www.for...506ff2cb73.jpg
Step 14:
Use 30MM socket to remove axel nut.
https://cimg5.ibsrv.net/gimg/www.for...63720af9ab.jpg
Step 15:
Use a 4lb hammer to drive half shaft out of the hub. *bonus* use 15mm socket (if I remember correctly) to remove wheel bearing (hub) assembly. Carefully pull ABS wires thought knuckle and set aside for later.
Step 16:
Remove strut from knuckle and set knuckle aside.
Step 17:
Grab half shaft and give it a good pull, you may have to tap on it a bit with your hammer but it will come out with relative ease.
Step 18:
With your half shaft removed, take a good look at your oil seal on the trans, replace if necessary.
BONUS!! If your lower control arm and ball joint were shot like mine, replace them now. I believe the bolts that hold the LCA to the subframe are 15MM. You will need a torch and penetrating oil here. These bolts are stuck in there pretty good. Heat the subframe, not the bolts.
Step 19: Reverse the process. I apologize but I do not have the torque numbers for this procedure, I just go as tight as I feel is needed.
Step 20: If you replaced your sway bar link, and tie rod end, give them just a couple pumps of grease. Be sure not to over do it and blow out the seals on your new parts.
Hayapower Sep 18, 2017 10:10 AM
Nice tutorial and images..
RiflemanD Sep 18, 2017 10:11 AM
Thank you. I tried to get it all, and only leave out the cussing that came along with the job...
Hayapower Sep 18, 2017 05:49 PM
Bloody knuckles? :)
RiflemanD Sep 18, 2017 05:52 PM
Not this time, luckily. Did bump my head quite a few times though lol.
