help !!!!
Good day !!! My name is Dimas, I own a 2005 freestar, and this is the problem I'm facing, it starts with a fault that looks as worn spark plugs (107000 miles), we changed together with the cables, the fault continues; then we changed the coilpak nothing happens, the compression was check and it was ok, we removed the computer and test it outside and it was ok, meanwhile we test the van with another comp. and the problem persist. Because the code shows a problem with the cylinder 2 we start checking the cables that goes from the comp to that cylinder, then we found an injector cable corroded so we figure out that was the problem so we changed the harness. Guess what ?? The fault stills !!!
Please, someone have a suggestion, solution, etc. HELP !!!! Thanks dimasp28:confused: |
What was the code you received?
help !!!
The code we're getting since the beggining is P0302 . I forgot to mention the egr valve was also changed
Thanks |
Problem solved !!! The fuel injector for the cylinder # 2 was consuming more amps than it need, so the computer feel the overheat and shut it down.
