No power steering
I've replaced rack and pinion twice, pump, pressure switch and flushed with Mercon V. Idk what else to replace except the hoses but there isn't a leak in the system. Van has 155k if that makes a difference. Original issue would come and go. Finally never came back so I checked to see if fluid was low, fluid was black. I proceeded to change out the fluid first with no luck. Pump never whined so I next replaced the RnP. I kept switching everything out, but still no luck. If you can think of anything else to check for please comment below.
thanks in advance. |
What is your actual symptoms? Have you checked the steering shaft knuckle (U-Joint) as it sets when it can get covered with eternal crud? When the U-Joint gets bad, it makes it hard to turn the wheels because it is binding. It also will not allow the wheels to return to center after a turn. Spray the U-Joint with some lube to see if the issue goes away. If it does, a new one is needed. It sets just above the rack. It's fairly easy to replace.
