P2196 code
bad idling? code P2196, first of all I had my catalytic converter cut off and had a pipe wielded on, but the wield wasn't closed at the top. ( I founded out later) could this be the problem with it running bad while idling?
Welcome mate on the forum. Go with this link may be its help
Anytime you remove something like the catalytic converter it can cause problems. If you have a CEL its almost certainly from the modification you made. I would suggest fixing the hole and see what happens after that.
