Power window problem
2004 Ford Freestar van. The power window, drivers side will not work. When I try to lower window all I hear is a "click". Is this something I can fix or do I have to take it to the dealer.
Could be the power window motor, or the window drive system is hanging up. I would remove the panel and check for voltage to the motor. If no voltage, it just may be the switch. Even though the switch is mounted into a switch cluster under the panel, I believe that the switches are still individually replaceable so that you don't have to purchase the whole switch cluster.
| All times are GMT -5. The time now is 05:19 AM. |
