Rear A/C squeal for 5-10 seconds when starting from cold
Old Jul 19, 2011 | 10:35 AM
olib's Avatar
Default Rear A/C squeal for 5-10 seconds when starting from cold
Hi,
I have a 2006 Freestar that has done 67,000 miles. Everything works fine including the a/c temperature however recently we have noticed a 5-10 second high-pitched squeal which sounds like it is coming from the rear a/c somewhere. Only happens after about 1-2 minutes of first starting the car.
Can't reproduce once the car has warmed up. Stops within a second if the main a/c button is switched off.
No problems with a/c temperature in back or front and no problems with engine itself or warning lights while noise is happening.
Any ideas?
Oli
Old Jul 19, 2011 | 01:53 PM
Use Common Sense's Avatar
Sounds like the blower motor for the rear A/C and Heat since that is the only moving part. The motor bearings may be running a little dry on lube. Do you have the electronic tri-zone or manual dual-zone system? Does it do it when you start the vehicle with the A/C off?
Hopley89
Jan 4, 2014 08:30 AM
ztywc2751
Dec 6, 2010 02:15 PM
sibiz5186
Dec 6, 2010 07:31 AM
danny88
Oct 9, 2006 11:30 AM
jrqf
Nov 7, 2005 04:32 AM
