04 Freestar 3.9 P0171 Lean Code
Old 02-10-2017, 06:54 AM
BradT's Avatar
Default 04 Freestar 3.9 P0171 Lean Code
My 04 Freestar w/ 3.9 has been throwing a P0171 Lean Code. Recently had an EGR code too. When replacing EGR noticed IMRC rods were off. Replaced bushings with aftermarket ones, rods continue to pop off.Could this be causing lean code or do I have an additional problem? Was going to replace all IMRC with Ford bushings this time. Do I possibly have a bad O2 sensor also?
Old 02-10-2017, 11:49 AM
Best to take things one at a time. Fix the bushing problem and see what happens after clearing the codes.
Old 02-19-2017, 05:05 PM
BradT's Avatar
Replaced IMRC bushings and still getting the P0171 code. Am I safe to assume I possibly have a vacuum leak somewhere causing this lean code?
Old 11-18-2017, 03:02 PM
Littlehawk's Avatar
Hey, Did you ever get it solved? I have a code U1059 that the ABS circuit is not communicating with the instrument cluster. Any ideas what specific problem that could be?
makuloco2000
12-07-2014 01:08 PM
makuloco2000
05-26-2014 09:53 PM
cjohnston2
12-22-2012 11:11 AM
Bob Wells
12-17-2006 11:24 PM
Quick Reply: 04 Freestar 3.9 P0171 Lean Code
