Ford Freestyle The new crossover, combining the versatility of an SUV with the compact size and feel of a station wagon.
Sinking brake pedal
Old 06-22-2017, 12:25 PM
DavidnJennifer Johnson's Avatar
Default Sinking brake pedal
Just changed brake pads like normal,... now brake pedal sinks on first stroke and then gets full pressure on second stroke. It always takes 2 strokes to get the brakes to have pressure. I have bled the brakes so much it's practically a full brake fluid flush. Seems like some fords ABS unit goes bad....but it was just totally fine before I changed my pads...no pressure problems before.
I am super poor so buying a part just find out it's something else is a big fear
Old 06-22-2017, 03:19 PM
To just replace pads alone is only half of the job and possibly is providing half of the good result.
Rotors will not always wear evenly and will usually wear more on the outside circumference than the inside toward the wheel center. When you put new flat pads on "not flat " rotors , the pad first contacts the higher part of the rotor and requires additional pressure to **** the pad and hopefully get full pad contact for stopping.
It is just poor practice to replace pads with having the rotors "trued" or replaced.
If you can't stop the vehicle when required, Is there such a thing as super, super poor?
msting
11-01-2007 05:10 PM
ras3355
11-10-2006 08:22 PM
machesked
06-05-2006 12:04 PM
cope607
03-13-2006 03:56 PM
css
01-17-2006 01:15 AM
Quick Reply: Sinking brake pedal
