2012 Fusion HVAC Blend Door Help Needed
I need some help with some issues with the blend door on my mom's 2012 Fusion. She has had it to a couple of mechanics and they have been unable to find the issue as its intermittent. The AC will run ice cold for a spell (1 to 5 minutes) then kick over to full heat. When this happens the blend door actuator is turning the blend door over to full hot (I had my finger on it when it happened). It doesn't appear that the door is slamming closed like the gears are stripped. It slowly moved as if operated by the actuator. Once this happens it will blow full hot until you restart the car. Here is what I have tried so far:
Anyone have any thoughts on next steps?
- Replaced blend door actuator.
- Calibrate the blend door actuator with a battery disconnect (several minutes).
- Calibrate the blend door actuator by removing fuse 15 for 30 seconds, turning on the ignition for 30 seconds then replacing the fuse and turning on the ignition for 30 seconds.
- Disconnecting the blend door actuator and manually turning the blend door to cold. Blew cold for at least 15 minutes. I needed to cool off its about 90 out.
Okos007
Jun 3, 2016 03:47 PM
