pmstumbo |
03-12-2018 03:12 PM |
2013 Ford Fusion water leaking into the passenger back floorboard...HELP?!
My 2013 Ford Fusion recently started having water soaking the passenger side back floorboard when it rains when sitting still in the parking lot. The backseat, roof of the car, under the front seat are not wet just the back floorboard. (I do not have a sunroof) I've had it put on a rack and checked all the drain plugs etc underneath and they all looked fine aren't missing etc. I've even got in the backseat with a flashlight and had someone run water over the doors to see if it leaked in around the seals and nothing. I've read online about a similar issue which involved a leaking cowl vent from drainage off the windshield leaking into the backseat. But is this possible if under the front seat isn't wet? Also one morning it had rained and the water was puddled on top of the carpet in the back floorboard which leads me to believe the water is leaking down onto the carpet instead of up from underneath. Anyone have any similar issue? If so what was the problem and how did you fix it? Also i have not been running the AC since its winter so i don't think it is the AC leaking.
